downstream O2 high voltage
Old Aug 24, 2013 | 06:06 PM
KillerKilgore's Avatar
KillerKilgore
Default downstream O2 high voltage
With the Downstream O2 giving high voltage is that leaning out the fuel or increasing?
Does the downstream O2 adjust the fuel/air or does it just monitor how well the cat is working and report for the emission?
Old Aug 24, 2013 | 09:12 PM
Tom A's Avatar
Tom A
Section Moderator
The downstream sensor is just there to measure cat efficiency. It has no effect on A/F ratio.
Old Aug 24, 2013 | 10:15 PM
KillerKilgore
Since I'm getting the high voltage on the downstream O2, does that mean that the upstream O2 is having issues?
Old Aug 26, 2013 | 12:42 AM
dangdakota's Avatar
dangdakota
I had the over voltage code for a downstream o2 sensor and no other codes. I replaced the downstream and started up to check if it did anything for the performance (which it didn't) and right away I got a new code for the upstream sensor. Replaced that and all is good now. I would go ahead and change it and see what happens.
