98 Dakota cummins 3.3 build
Old Sep 17, 2013 | 10:18 PM
deck60's Avatar
deck60
Oil System Capacity (Turbo) 8.5 U.S. qt 8 liters
Length 27.7 in 703.4 mm
Width
22.8 in 580 mm
Height 31.7 in 804.9 mm
Wet Weight 606 lb 275 k
didn't find any specs on the 3.9 dodge will put a tape on it tomorrow
Old Sep 17, 2013 | 11:03 PM
magnethead's Avatar
magnethead
ouch, 600 pounds? That's mighty heavy for a 4-banger! I'm not even sure what front springs to suggest. Stock V8 springs sure won't do it.
Old Sep 17, 2013 | 11:38 PM
deck60's Avatar
deck60
how much does a v8 weigh anyway I was figuring 600lbs for a v8 right now I want to get it in and running and then go for suspension
Old Sep 18, 2013 | 12:13 AM
magnethead's Avatar
magnethead
Our 565 race block is something like 400 pounds on the engine stand (raw stock block was 205 pounds, DART race block is 270) . Transmission is another 125 pounds. And a big block chevy should weigh a hell of a lot more than a small block mopar.
Old Sep 18, 2013 | 03:04 PM
deck60's Avatar
deck60
i found specs for the 360 5.9 550-600 depending if it is California or not California is 50 lbs heavier
I posted some new pictures on photobucket http://s1125.photobucket.com/user/de...dakota%20build
did a pan modification this mod will give me 3" of extra height should sit better in the engine bay less of a hood scoop I will need a hood scoop for the inter-cooler anyway and the fuel pump is mounted 14psi
Drew the guy I bought this engine from did me a huge favor he had the sn for the engine
I had taken the plate off and it got misplaced but now I am good
Old Sep 18, 2013 | 03:31 PM
magnethead's Avatar
magnethead
600 pounds for the 5.9 gas motor? Something don't seem right there...
Old Sep 18, 2013 | 03:59 PM
deck60's Avatar
deck60
this isn't the site i found earlier but they say 550 for mopar 360
http://www.gomog.com/allmorgan/engineweights.html
Old Sep 18, 2013 | 04:35 PM
magnethead's Avatar
magnethead
wow. didn't realize the assembly was that heavy. Like i said, we scaled our stuff when we got it. 270 for the block, iron heads are 70 a piece, our aluminums are 45 a piece, crank is 50 pounds or so, each piston is 630 grams (11 pounds total), connecting rods are 815 grams (14 pounds total), intake manifold is 25 pounds. That adds up to 460 pounds (510 pounds if you want the iron head number). And that's for a 565 inch big block.
Old Sep 18, 2013 | 07:07 PM
deck60's Avatar
deck60
yea but you don't have an ac unit power steering and probably not an alternator and headers instead of cast iron exhaust manifolds it all adds weight
and I think Mopar has usually had a heavier engine than gm any way
Old Sep 18, 2013 | 10:00 PM
magnethead's Avatar
magnethead
this is true.
