Sway Bar End Link Extensions
Old Sep 13, 2013 | 06:08 PM
01dak3.9's Avatar
01dak3.9
Default Sway Bar End Link Extensions
I am still deciding weather to lift or lower my truck but the problem with lifting it is the front sway bar. I would put a 3" suspension lift along with a 1" spacer and a 3" body lift. The problem is with the front sway bar. How would I extend the end link or would I extend the mount? I will also put a rear sway bar on it and I would extend the mount for that to? What size tires would I be able to fit with all that lift?
Old Sep 13, 2013 | 11:21 PM
01dak3.9's Avatar
01dak3.9
Could I put a coupler nut on the stock end link with locktite nd a jam nut and then put some stainless threaded rod above that? All grade 8 of course.
Old Sep 14, 2013 | 01:08 AM
magnethead's Avatar
magnethead
I think most kits drop the sway bar chassis mounts with pads.
Old Sep 14, 2013 | 07:27 AM
01dak3.9's Avatar
01dak3.9
Oh. I didn't know that. Thanks.
