tune up
Old Oct 9, 2013 | 09:02 PM
98DAKAZ's Avatar
98DAKAZ
Lightbulb
I have a very different engine the 2.5 an I usually don't try the fancy spark plugs much but I tried the Bosch Fine Wire Iridium Spark Plugs over a year ago I just pulled two to check things out.
I was surprised as they were the cleanest plugs I have ever pulled they looked almost new the Iridium points were super clean and shiny like the day I put them in the burn was excellent. I did also install an excel hot coil at the same time and widened my gap .05 from stock.
I would say the best plug I ever used
Old Oct 10, 2013 | 09:26 AM
idiggplants's Avatar
idiggplants
Originally Posted by 00DakDan
While you're in there check the belt and hoses too. Top off all the fluids.
5w-30 or 10w-30 would be fine. Check the owners manual. There's no need to go heavier.
owners manual? lol that is grand. that probably got tossed somewhere around 2000.
5w-30 itll be. winter is upon us up here in PA.
thanks for everyones suggestions. think ill stick with the stock temp plugs. unfortunately this is all coming from advanced auto. she has a gift card, and will be doing all the purchasing.
should i start a new thread on the heater repair? id like to know how to check the blend door and resistors.
Old Oct 10, 2013 | 01:25 PM
01SilverCC's Avatar
01SilverCC
If buying from Advance you can go online at www.retailmenot.com and or just Google search for "Advance Auto Parts Coupons" and you should see their current discount codes listed. Buy online and pick the parts up at the store. I have saved a ton of money the last few years with the AAP discount codes. I would say do not buy their cheaper line of ignition parts. You may have to call the store and ask but they probably do have better quality parts available. Ignition parts and sending units are two things where it really pays off to get the best parts you can afford. The online discount codes do not apply to oil but you can use the codes on filters.
Jimmy
