transmission test port?
My next question I hope someone can help with....
I want to install a transmission temp gauge. I am told the senders for these are normally installed in a factory test port location on the side of the transmission. Normally found in front of the pan or close by that area.
I am getting crazy rain where I live right now so I can't (don't wanna lol) go crawl under the truck. Does anyone know if the Dakota has a test port on the transmission? If so, what size are the threads?
Thanks very much.
2004 QC 4x4 w/ 4.7
Thanks very much.
2004 QC 4x4 w/ 4.7
Thanks very much.
2004 QC 4x4 w/ 4.7
Thanks very much.
2004 QC 4x4 w/ 4.7
be sure and use high pressure hose on any chrusler TF cooler lines. also found this good EXTERNAL fluid filter.
man o man i about forgot yes its a cut & past sorry. __________________
after you clean the trans. add this to your*chrysler*trans. an external fluid filter
1. go to auto-zone. get 2210, its called a power steering filter, but it is for transs to. it is for 3/8 tubing. by (magna-fine) be sure to use high pressure hose. Reff:http://www.magnafilter.com
2. for other sizes wix 58964 5/16 tube size
Thanks for the info.
Magnethead, I assume you are saying to cut the steel line and install a rubber hose in-line with two hose clamps. The sensor will be installed into the rubber hose. I like the idea very much. I will definately copy your method!
Is there any way I could trouble you for a picture of where you put yours?
Or maybe you could just explain the location in detail for me? I have not been under the truck with the purpose of finding these lines yet.
Thanks for the tip very much!
If you have a flaring tool, it helps if you add a shallow flare the the steel lines when you cut it, as it helps secure the rubber hose (but not too much flare, will cut the hose). Yes, use high pressure 3/8 ID hydraulic hose. Typ system pressure in reverse is about 300 PSI. And even with the flares, put two hose clamps. I have about 6 inches of steel/rubber overlap, with flares, and two hose clamps 3 inches apart.
I'll take a pic of the setup and post tomorrowish.
I added a 16 pass cooler with 10" fan in-line to the factory cooler, it's mounted under my bed. So I just have the sensor in that rubber line. I have the sensor between coolers on mine, so it's not a "true" trans temp, but it gives me an idea of what it is. As I recall, the fluid flow comes out of the front pump, through the factory cooler, then I added the temp sender and the 16 pass, then the inlet is on the tailhousing.
Okay I think I got it. I like the idea of adding a second cooler. After I get the gauge in there I will decide if I want to add one or not. I did trace my lines today and figured out that the aux cooler I have on the truck is in fact for the trans so I am very pleased that I do at least have a OEM cooler on it.
Would love to see picks of your setup if you do find time to snap some.
Thanks!
