Coolant Leak..... Somewhere
Old Nov 25, 2013 | 08:45 PM
magnethead's Avatar
magnethead
Go to Autozone and rent a cooling system pressure tester. Pump it up and you'll see where it's leaking.
this. It works wonders.
Old Dec 4, 2013 | 05:50 PM
dakotamod21's Avatar
dakotamod21
I took the belt off and grabbed the pump pulley and there was a lot of play in it so either way I have to replace the pump along with the bypass hose. Since Ill have it apart I'm replacing the thermostat w/ gasket too.
