Check Gages Light - Oil Low
Old Nov 27, 2013 | 07:14 AM
rbm124's Avatar
rbm124
New Member
Default Check Gages Light - Oil Low
My Check Gages Light came on. Found the Oil pressure gage was zero. Turned truck off for a few seconds and restarted and all the gages were normal. This has happened every 3rd or 4th time I start the truck. Any ideas what the problem could be?
Old Nov 27, 2013 | 09:21 AM
01SilverCC's Avatar
01SilverCC
It could be a bad sending unit, it's kind of a common problem on Dodges but you can check the oil pressure for sure with a mechanical gauge. You can buy one cheap at Harbor Freight or maybe rent one from a parts store. If the truck runs OK and has no knocking noises and the oil level is OK the problem may be electrical like a bad sending unit or a wiring problem.
Jimmy
Old Nov 27, 2013 | 09:26 AM
bohnjerry's Avatar
bohnjerry
Default Think it is a bad contact.
This happened (still occasionally) on my 2004 Dak.
I posted here and everyone screamed "oil screen".. better change it or you'll blow your engine.. like some chant.. I knew it couldn't be, since my wife drove it over an hour home on "zero" oil pressure and not a drawback to be seen...
I found it to be bad contact(s) within the key switch in the steering column. I found one day I had no cabin fan and other readouts, and happen to brush my hand by the key ring, and everything blipped back on (except oil pressure).
The oil pressure gauge is a rebel, however. If something’s amiss, it simply refuses to cooperate at all. If you turn the key to off and back on before the engine has a change to stall the oil pressure will instantly jump to normal pressure. I know if it was a blockage that I dislodged, like others claim, I would still have to begin to build oil pressure not instantly land in the middle of the dial.
I have yet to replace my contacts, tumbler, or whatever is in the parts set.. Since I only have one chip key, and don’t want to mess with the dealer “unlocking”anything, and since I’m also a cheapskate, I don’t bother if it isn’t harming anything. I do, however, do that key thing just because that low pressure gauge does bother me… just in case it is ever the real thing.
Old Nov 27, 2013 | 12:47 PM
Dodgevity's Avatar
Dodgevity
The oil pressure switch has probably bit the dust. They're around 15 bucks or so at the parts stores.
