neutral saftey switch help
Old Feb 13, 2014 | 07:38 PM
BlackDakotaV8_4x4's Avatar
BlackDakotaV8_4x4
Default neutral saftey switch help
need help jumping the pigtail that was in my automatic trans so when i get done with the swap i will be able to start my truck up and all!!!!
File Type: jpg
Old Feb 13, 2014 | 09:00 PM
BlackDakotaV8_4x4
And I also need help on how to turn off the transmission temp light since the automatic transmission is being taken out?
Old Feb 13, 2014 | 09:02 PM
magnethead's Avatar
magnethead
FSM should show the neutral switch...I believe it gets replaced by a clutch safety switch.
Also, the trans temp light runs through the PCM on the communications buss for the transmission. In addition to that light being on, you'll likely get a whole slew of P codes for improper RPM drop, open connection to convertor solenoid, open connection to overdrive solenoid, trans too hot, among others.
