lift kit
Old Feb 23, 2014 | 10:44 PM
kickerman's Avatar
kickerman
Ok and how much do you think it will be for the ball joints?
Old Feb 23, 2014 | 11:00 PM
Tom A's Avatar
Tom A
Section Moderator
IF the stock ones fit, they're around $40 each.
Old Feb 24, 2014 | 06:24 AM
kickerman's Avatar
kickerman
Ok and there's four? Also can I measure the wheel I have now to see if they have correct back spacing ? If so I measure from the middle of the wheel where the lug nut hole are
Old Feb 24, 2014 | 07:41 AM
Tom A's Avatar
Tom A
Section Moderator
Yes, there are four. But you're only replacing the upper control arms, so you can probably keep your lower ball joints if they're in good shape. To measure backspacing, lay a straight edge across the back of your wheel (not tire) and measure from there to the back of the wheel hub. But, if you have the stock wheels, I'm guessing they have too much backspacing.
Old Feb 24, 2014 | 08:28 AM
kickerman's Avatar
kickerman
Ok we'll all do so later in the evening so if the back space is 5 3/4 I'm ok
Old Feb 24, 2014 | 08:34 AM
Tom A's Avatar
Tom A
Section Moderator
No. It needs to be 4-5/8" or less.
Old Feb 24, 2014 | 05:03 PM
kickerman's Avatar
kickerman
Ok my back spacing is 5 1/2...
Old Feb 24, 2014 | 05:23 PM
Tom A's Avatar
Tom A
Section Moderator
So you could get away with 1" spacers in front.
Old Feb 24, 2014 | 05:43 PM
kickerman's Avatar
kickerman
How safe are those? I've herd a little bit about spacers
Old Feb 24, 2014 | 05:54 PM
Tom A's Avatar
Tom A
Section Moderator
There's another recent thread about spacers/adapters (6-lug Chevy conversion or something like that). Lots of info in there. You don't need adapters, but all the same info applies to spacers.
