1998 speedometer not working at all
Old Mar 28, 2014 | 08:03 PM
bbq_in_the_rain's Avatar
bbq_in_the_rain
Default 1998 speedometer not working at all
I have replaced both sensors and I still get nothing. any suggestions on what to do next?
Also, any ideas where I can get a service manual or wiring diagram free or really cheap?
Old Mar 28, 2014 | 08:09 PM
dodgedakota98luver's Avatar
dodgedakota98luver
Did you replace the harness for the sensor on the rear end? Could be a broken wire right there. Some sensors come with the harness some dont
Old Mar 29, 2014 | 12:37 PM
bbq_in_the_rain
I did not. I made the assumption that the wiring is OK because when I unplug the sensor the ABS light comes on and when I plug it back in the light goes off.
Old Mar 29, 2014 | 08:48 PM
KillerKilgore's Avatar
KillerKilgore
https://dodgeforum.com/forum/2nd-gen...-download.html
Shot in the dark here.
Check grounds for instrument cluster think there behind the kick panels on driver and passenger side. Check and clean contacts for instrument cluster. Had similar issue with instrument cluster but it was all gauges. Turned out to be the ground behind kick panels.
Old Mar 30, 2014 | 03:14 PM
bbq_in_the_rain
Thanks, I'll give that a try.
