97 Dakota no start, no spark 3.9L
Old May 14, 2014 | 10:52 PM
hotrod_nolte's Avatar
hotrod_nolte
OK I found the main problem!! Broken ground wire that bolts to the front Left of the engine. G107 I believe. Now my readings to the crank sensor are correct, but still won't start. Check engine light came on and I'm getting a Cam sensor code
Old May 15, 2014 | 12:45 AM
T-Ram's Avatar
T-Ram
Check for shorts-follow all wires also make sure you didn't pinch any wires between your engine and transmission housing-sounds like a short-
Old May 19, 2014 | 09:01 PM
hotrod_nolte
Still no spark- code P0340 cam sensor circuit failure. No shorts found, no pinched wires found. It has 5 volts to the cam sensor, but the signal and ground from the sensor are erratic.
