Dang on gremilns
Old Jun 10, 2014 | 06:18 PM
dragordie's Avatar
dragordie
Default Dang on gremilns
Hey, 2002 Dodge Dakota 3.9 133k miles auto trans. thought i had EVAP problem with the codes P0442 and misfire 1,2,3,5,6 replaced every vac hose no more check lights but still have a drivabuilty issue when i first start driving first gear shifts to second and the power band almost shifts into 3rd but looses all power it hesatates and misfires if I stop at a stop light it almost dies. take off and punch it it stumbles and has no power than like lighting a fire cracker it takes off than no more problems until i shut it off and it starts all over again. was told it might be the lower pan gasket on the intake ? anybody have any Ideas. Frist Dakota, I'm no stranger to turning a wrench Ive been building rock crawling jeeps for 20 years but this has me stumped.
Old Jun 10, 2014 | 06:59 PM
sxrsil3nt's Avatar
sxrsil3nt
Pull the air hat off of the throttle body and open the butterfly.
Shine a light down - if you see a lot of oil then your plenum gasket is bad. Very common problem on the magnums.
O2 sensors may be another area to look out for.
Old Jun 11, 2014 | 05:30 AM
dragordie's Avatar
dragordie
Thank you for the advice sxrsil3nt. I will give those suggestions a try.
Have a great day up north my friend.
Old Jun 11, 2014 | 11:34 AM
sxrsil3nt's Avatar
sxrsil3nt
Cheers brother!
Good luck with your truck and let us know if you've solved your issue.
If you're also losing oil I'd bet its the plenum gasket. I also suggested O2's since I had a nasty backfire similar to your description and after new plugs, wires, cap and rotor turns out it was the Bank 1 upstream sensor. No codes either.
