Headlight flickering
Old Jun 11, 2014 | 05:47 AM
Dakota_girl27's Avatar
Dakota_girl27
Unhappy Headlight flickering
I have a 97, I have noticed that my headlights flicker when I'm driving. I have my fog lights on and the stay on same with my running lights and dash. What's going on?
Old Jun 11, 2014 | 07:42 AM
Welcome to the forum. Have you inspected the headlight connections? Could be loose and causing the issue with flickering. Check the alternator and drive belts as well.
Old Jun 11, 2014 | 09:53 AM
Dakota_girl27
Checked all that. My alternator is fine. It only happens when I'm driving and it start about 10 min after starting the truck.
Old Jun 11, 2014 | 12:31 PM
racecart1's Avatar
racecart1
May be there is some dust in the wire, Unplug those and clean the wire and try to install it.
Or may be there is some power supply issue. Does it happen with both the light simultaneous ?
Old Jun 11, 2014 | 05:48 PM
LIZZRD's Avatar
LIZZRD
Pretty sure it is the relay located in left side of dash, the little access door in the pic., it is about a 1 1/4" square black or grey. Drive it to the part store and take it in... i think mine was about $8.
OR, the switch is the next move. It really is a kind of easy job, it plugs right into the harness shown.
Old Jun 12, 2014 | 05:58 AM
Dakota_girl27
It's happens Ina continues pattern. I'll try what you guys said and go from there. I just got to get it fixed soon, a cop pulled me over yesterday for it and told me to get it fixed and gave me a ticket. Could it be a Bad fuse connection at all?
Old Jun 14, 2014 | 07:38 PM
LIZZRD's Avatar
LIZZRD
How is your 'light' problem going ?
Old Jun 15, 2014 | 04:07 PM
Dakota_girl27
Haven't been able to check anything yet. I don't even know where to start really in thinking I'll start at the harness and move up. I had to fix my brakes and now I'm at a stand still till I get paid. Hopefully it's not major.
Old Jun 15, 2014 | 08:58 PM
LIZZRD's Avatar
LIZZRD
you see that little access door on the side of the dash ?
... check that relay at the part store, it fairly cheap.
Old Jun 16, 2014 | 12:04 PM
Brian in Tucson's Avatar
Brian in Tucson
Check your grounds. Bad grounding will cause the headlights to flicker.
