Stripped Caliper Threads on Steering Knuckle
Old Jun 23, 2014 | 10:23 PM
Tom A's Avatar
Tom A
Section Moderator
Considering the price of the oversize pins, I would Heli-coil it. The Heli-coil kit comes with enough inserts to do all four of them if you need to. Much better deal, IMO.
Old Jun 23, 2014 | 10:59 PM
KillerKilgore's Avatar
KillerKilgore
If heli coiled, would oem pins work or would you need to get pins to match heli coil innards?
Old Jun 24, 2014 | 12:00 AM
Tom A's Avatar
Tom A
Section Moderator
The stock ones would fit.
Old Jun 24, 2014 | 09:19 AM
sxrsil3nt's Avatar
sxrsil3nt
Killer asked my exact question, so I believe the thread size is M9 x 1.25
Thanks Tom, this is what I needed to know.
I found the helicoil kit on amazon for $35 + $5 shipping, and with the cost of new pins I'm looking at about half the cost compared to the over sized ones.
Old Jun 24, 2014 | 04:11 PM
KillerKilgore
found this while researching my issue. It for a 97 but ...
https://dl.dropboxusercontent.com/u/43814309/051181.pdf
Old Jun 24, 2014 | 05:11 PM
sxrsil3nt's Avatar
sxrsil3nt
Thanks Killer, I found a ton of threads for 97/98 Dakotas and they all used a M9x1.25 tap.
I compared the caliper pin part #'s on Rockauto for 97/98 and my 02 and they are the same.
Helicoil is in the mail and should have it early next week.
Old Jul 25, 2014 | 03:14 AM
04 Quadcab's Avatar
04 Quadcab
Default + loctite
Had same problem on my '01 Intrepid. I'm pretty sure it happened when I had a tie rod end replaced--lazy cruds probably took off the caliper and put it back on with an impact wrench. Like someone else said, the torque specs on these are less than 20 lb-ft.
Anyway, I took the car to a local mechanic when I couldn't get either the old pins or new ones to bite. They put in helicoils and used Loctite green. Said it would never come loose, but you'd never get the pins out again; they'd break off and you'd end up drilling them out.
Old Jul 25, 2014 | 10:01 AM
sxrsil3nt's Avatar
sxrsil3nt
I ended up helicoiling the threads - the size was M9x1.25mm
I bough all new stock sized pins and I'm pretty sure they came with antiseize - not loctite. I'm surprised they put loctite on your Intrepid even after helicoiling.
Anyway, thanks for the tips!
Old Oct 3, 2015 | 06:20 PM
dodgedartmike's Avatar
dodgedartmike
Default Great Advice
I had the same problem with my 2001 Dakota 2WD Crew Cab 3.9V6
Thanks for the advice to get an over sized pin for my stripped out steering knuckle. Today I purchased the one suggested from Advance Auto and it worked great. I didn't even remove the tire just turned the wheel to one side to gain better access!
