any ac guys want to help with my 1997 5.2
Old Jul 21, 2014 | 04:51 PM
98DAKAZ's Avatar
98DAKAZ
The valve kit it should include the extractor the brass valves are not used on the Dakota
Old Jul 21, 2014 | 04:56 PM
98DAKAZ's Avatar
98DAKAZ
Wink
You can get a screwdriver made to remove the valves
Amazon.com: Schrader  20141 Schrader Valve Core Torque Tool: Automotive Amazon.com: Schrader 20141 Schrader Valve Core Torque Tool: Automotive
Old Jul 21, 2014 | 06:07 PM
97dakota5's Avatar
97dakota5
cool thx again dakaz i appreciate all the advice
Old Jul 21, 2014 | 11:53 PM
Tom A's Avatar
Tom A
Section Moderator
Does your friend with the shop have an electronic leak detector? That's the best way to find leaks. Put about 1/2lb. of refrigerant in the system and sniff around all the connections with the leak detector. Stick it in the inside vents to see if the evaporator is leaking.
Old Jul 22, 2014 | 05:33 AM
98DAKAZ's Avatar
98DAKAZ
True a leak detector is the best if you can get your hands on one.
The dye is old school but still used by most as its easy just to pump the dye in and it cost the shop almost nothing.
Old Jul 26, 2014 | 07:31 PM
97dakota5's Avatar
97dakota5
Yeah his machine that pumps refrigerant in also tells if there is a leak but doesn't tell you where to look haha
