Engine Mounts - Hoist points
Old Aug 20, 2014 | 12:39 PM
jondakotaguy's Avatar
jondakotaguy
Default Engine Mounts - Hoist points
Sorry I did a search but returend nothing but fan stuff and various engine stuff.. not quite what i was looking for.
Been about 14 years since the last time i hoisted an engine; my 97 Dakota 4x4, what is the best point to hoist with and engine lift?
Exhaust manifolds hold up ok?
Old Aug 20, 2014 | 12:44 PM
sxrsil3nt's Avatar
sxrsil3nt
When I did my swap I found a hard time looking for spots on the 3.9, I ended up wrapping a strap around the crank shaft (behind the crank pulley) and behind the flex plate. Not sure if this is a good way or not but it worked fine lifting 3 separate engines.
Wouldn't trust the exhaust manifolds.
Old Aug 20, 2014 | 12:57 PM
magnethead's Avatar
magnethead
I would use the ground bolts in back of the cylinder heads and the accessory bracket in the front.
We lift the race motor by 4 exhaust header bolts. NASCAR and many others lift by the intake. Not sure if the beer keg would be strong enough or not.
Old Aug 20, 2014 | 01:59 PM
jondakotaguy
Just to do engine mounts im thinking exhaust manifolds should be strong enough points.
and ill stick a jack under the engine i'd rather tear up my oil pan than my hand or arm.
jack stands to hold up the front transaxel.
