04 dakota steering wheel skakes
Old Sep 28, 2014 | 07:35 PM
number2sub's Avatar
number2sub
Exclamation 04 dakota steering wheel skakes
The truck started shaking at 65mph and above. It also needed ball joints, so I got them replaced 2 upper and 2 lower. Still happening, replaced shocks (Gabriela ultras), and sway bar bushings, and cv axles. Still happening but only if the wheel isn't straight. I also got an alignment done. I have no idea what it could be?
Old Sep 28, 2014 | 08:02 PM
magnethead's Avatar
magnethead
did they check the rack when they did the alignment? My last alignment they caught my steering rack being loose, even though I couldn't feel it in the wheel, took 2 turns to take the bolts to 90 ft-lb. Is the driveshaft out of balance or bowed? That would easily do it. The DS in our camaro was 1/8" bowed and 10 grams out of balance and it shook the whole car from 330 on till we had it repaired.
Old Sep 28, 2014 | 08:20 PM
98DAKAZ's Avatar
98DAKAZ
Exclamation
Out of round tires unbalanced tires poor wheel adapters if you have them could be a number of things.
Bent rim bent axel bad U-joint lose engine mount or trans mount.
Old Sep 28, 2014 | 08:56 PM
Dodgevity's Avatar
Dodgevity
Rotate rear wheels to front. See if that changes things, that way you can narrow it down.
