upper control arm bolt torque
been arguing with 2 firestones, finally called and made a complaint and was told to come to a third store. Manager seemed somewhat nice.
Problem is that control arms have been collapsing. Took a torque wrench, figured out that the alignment nuts haven't been getting tightened much past hand tight. I took them to 165 ft-lb. Anybody know what the true spec is? Factory alignment spec is +3 degrees caster, -0.25 degrees camber, +0.1 degree toe on page 2-5.
edit- found it 155 ft lbs, page 2-7 and 2-14 of the manual.
155 ft lbs. that's it
That can explain why your alignment has been going out on you
In 16 years my alignment never dropped or needed done only reason I finally got it done was new bushings and ball joints.
TORQUE CHART
DESCRIPTION TORQUE
Shock Absorber
Upper Nut . . . . . . . . . . . . . . . 26 N·m (19 ft. lbs.)
Lower Bolts . . . . . . . . . . . . . . 28 N·m (21 ft. lbs.)
Lower Suspension Arm
Front Nut . . . . . . . . . . . . . . 175 N·m (130 ft. lbs.)
Rear Nut . . . . . . . . . . . . . . . 108 N·m (80 ft. lbs.)
Ball Joint Nut . . . . . . . . . . . 127 N·m (94 ft. lbs.)
Upper Suspension Arm
Pivot Shaft Nuts . . . . . . . . 167 N·m (130 ft. lbs.)
Pivot Shaft to Frame Nuts . 210 N·m (155 ft. lbs.)
Ball Joint Nut . . . . . . . . . . . . 81 N·m (60 ft. lbs.)
Stabilizer Bar
Link Upper Nut . . . . . . . . . . . 37 N·m (27 ft. lbs.)
Link Ball Stud Nut . . . . . . . . 47 N·m (35 ft. lbs.)
Retainer Bolts . . . . . . . . . . . . 60 N·m (45 ft. lbs.)
Hub/Bearing
Spindle Nut . . . . . . . . . . . . . . 251 N·m (185 ft. lbs.)
TORQUE CHART
DESCRIPTION TORQUE
Shock Absorber
Stabilizer Bar
Hub/Bearing
Are these specs for a 2003 dodge dakota upper control arm?
TORQUE CHART
DESCRIPTION TORQUE
Shock Absorber
Stabilizer Bar
Hub/Bearing
Spindle Nut . . . . . . . . . . . . . . 251 N·m (185 ft. lbs.)[/QUOTE]
TORQUE CHART
DESCRIPTION TORQUE
Shock Absorber
Stabilizer Bar
Hub/Bearing
