p0351 1997 Dakota 3.9l
Old Jan 12, 2015 | 12:50 AM
franco1978's Avatar
franco1978
Default p0351 1997 Dakota 3.9l
My 1997 Dakota kept stalling after a minute or so of idling. Looked around a couple of threads and not much luck because the only code I was getting was p0351. I checked all ignition wires for damage and wiggled the PCM harness. But when I removed the auto shutoff relay I found some corrosion. Truck had sat for 2 months. I cleaned all the relays with electronic spray cleaner and the problem went away. Also noticed that my A/C compressor kicked on once I cleaned the connections on the relay. I thought it was low on freon and was going to wait until summer to fix the leak.
