whats going on???
Old Oct 28, 2005 | 04:25 PM
craigstockman's Avatar
craigstockman
Default whats going on???
Okay here is the deal. my 2000 4x4 is about 3/4 inch lower on the passenger side than the drivers. I have checked the torsion bars and they are both maxed out. What else could be causing this. Its really starting to **** me off. any suggestions would be greatly appreciated. thanks for all your help.[:@]
Old Oct 29, 2005 | 06:40 AM
RP Racing940's Avatar
RP Racing940
Default RE: whats going on???
Maybe a rubber isolator decided to go on vacation. I know T10/15 (4wd S10's and sonomas) isolators were about .75" also. Replaced mine a BUNCH of times.
Old Nov 6, 2005 | 02:07 AM
craigstockman
rubber isolator? Is that like a body mount. I am a little brain dead currently, I've been in kansas too long.
Old Nov 6, 2005 | 03:45 AM
DanDB64's Avatar
DanDB64
Mines the same way, except i lowerd the higher side via torsion bars
That works too
Old Nov 6, 2005 | 10:52 AM
RP Racing940
ORIGINAL: craigstockman
If dodge is similar in setup to my sonoma, between where the torsion bar mount under the cab is theres a piece of rubber that cusions the torsioin bar arm and stops it from clunking when the siuspension cpmressess.
Old Nov 19, 2005 | 09:46 PM
Kuddlebunny75's Avatar
Kuddlebunny75
there should be a spring rubber in the bottom or top of the spring.......check to see if it is missing....if it isn't then it could be a weak spring.
