Front End Pull
Old Mar 13, 2015 | 10:37 PM
98DAKAZ's Avatar
98DAKAZ
Cool
Don't forget all OEM tires that come on autos are garbage and never last long you just know they will only give you 2 or 3 years at best and they always suck.
So don't judge a tire company by OEM tires
I have had good luck with a few Goodyear tires that I owned
OEM tires are low grade thin tires usually not always but usually part of the upsell so they can make a few hundred more off you.
Old Mar 14, 2015 | 10:31 AM
patchelect's Avatar
patchelect
OEM tires are on the vehicle so they manufacturer can claim certain fuel economy numbers and also to keep the rims from getting scratched up as well.
Old Mar 18, 2015 | 09:10 AM
jondakotaguy's Avatar
jondakotaguy
The duratracs on my truck even considering the slight wear on otter edge from alignment issue that i solved right as they were semi new; didn't like wet anything unless it was a pond of muck.. tires seemed to wear down like cake at a BBW convention... thought they had some amazing traction for being all terrain.. They only had about 26K miles on them but were rated for much more.. i was already almost down to the markers and i hardly ever drive this truck and kept up with rotation. I'm not sure I'd ever use them again.
Old Mar 18, 2015 | 09:57 AM
Dodgevity's Avatar
Dodgevity
HEHE!.... Jon, you were in attendance? I'm getting worried about you.
Old Mar 20, 2015 | 10:24 PM
lambs's Avatar
lambs
I had Goodyear "Integrity" tires on my Highlander. One of them blew the sidewall out at 29k. So much for integrity. I replaced the whole set with Michelin LTX. I put 108k on them and they still had some tread on them when I bought another set of them.
Unfortunately at the time I bought my Dakota ('97 Sport), Michelin did not make an LTX in the size I needed. I'm running Uniroyal Laredo on it and have no complaints so far.
