Wheel Hub Assembly
Old Jul 21, 2015 | 10:56 PM
AndrewMorin's Avatar
AndrewMorin
Default Wheel Hub Assembly
Hey guys, I just took off my wheel hub assembly and I noticed it wasn't an ABS one but before I even took it off, I went and ordered one but it was an ABS kind and i figured mine was too but it's not. Will the ABS one I ordered work with my truck when it wasn't an ABS Hub Assembly to begin with or do I have to get a non ABS kind?
Old Jul 21, 2015 | 11:00 PM
98DAKAZ's Avatar
98DAKAZ
Not sure but I would send it back did you already pull your Hub off?
Ops just noticed you did just woke up yea I would send it back but remember if is 2WD you must replace the nut.
Old Jul 21, 2015 | 11:11 PM
AndrewMorin
its an AWD truck. you should have a coffee asap haha. i wonder if theres a way to hook up the abs if its not a lot of trouble
Old Jul 22, 2015 | 12:15 AM
98DAKAZ's Avatar
98DAKAZ
Wink
Now who's asleep?
No not possible without lots of money and time not worth it plus you would need the other Hub replaced.
It may not make a diff but I would return it the ABS Hubs cost more anyway.
Old Jul 22, 2015 | 12:22 PM
AndrewMorin
okay. gonna send it back and go to canadian tire. hopefully they have one. thanks
Old Jul 22, 2015 | 12:45 PM
98DAKAZ's Avatar
98DAKAZ
If one Hub is bad usually the other is not far behind best to replace both at the same time. I have installed one ebay no name Hub and one Timken no problems from either be sure to not over tighten the nut stick to the recommended torque over tightening them damages the bearings.
