dodge runs bad
Old Aug 15, 2015 | 12:14 AM
roblaws's Avatar
roblaws
Default dodge runs bad
hi all got a good one for you. i have 1997 dodge dakota 318 5.2. i put new heads on it all new gaskets, a new crank and pick up and cap rotor new plugs wires new iac and idle control. when you start it up runs like crap sounds like missing and back fires can't get no power out of it ( has about 128000. miles on it. people are telling me that ecm is bad, timming chain is out or dist is bad) i got a lot of money in it so far can't seem to figure this thing out can anyone throw me some ideas. Thanks for reading this could us any help. also it is not throwing any codes
Old Aug 15, 2015 | 03:44 AM
98DAKAZ's Avatar
98DAKAZ
Try putting the old crank sensor back on see if that helps check wires one may be off.
Old Aug 15, 2015 | 08:15 PM
roblaws's Avatar
roblaws
i would if my son didn't loose it. can't find it anywhere
Old Aug 16, 2015 | 08:51 AM
Robertwav1's Avatar
Robertwav1
I went through a battle such as this not to long ago with a 98 Dakota so I don't think they are that much different. I assume compression is good, if it is I would suggest going over everything again. I have had a lot of problems with new parts, keeping the old ones and throwing them back in was well worth it. The distributor inside under the prox switch (if your truck has this), check and make sure it's not floating around, it's a metal piece that makes and breaks the prox switch. O2 sensors, upstream, keep as suspect as well. PCM could be the culprit but recheck everything first before condemming that. Keep a history on what you do, it's easy to get fooled by multiple problems.
Old Aug 16, 2015 | 09:47 PM
roblaws's Avatar
roblaws
thanks for info i went ahead and cheked all the wiring cause i thought the mice had chewed it up but didn't find any chewed. i did notice that the crank sencer had scuff marks on it so i wonder if factory one is different shape of oem replacement. been on a 9 day work week going to go at the truck on tues will let you kmow what i find. thank you again.
