Bad Fuel pump? Aftermarket?
Old Aug 28, 2015 | 06:51 PM
  #21
Charvet7's Avatar
Charvet7
Truck has been running fine now last 2 days. Intermmitent issues are always the most difficult. Anybody have any other ideas or input on the battery condition?
Old Aug 29, 2015 | 02:37 PM
  #22
Charvet7's Avatar
Charvet7
Truck not starting again now. Very clear the fuel pump is not kicking on. Double checked the 02 sensor relay and the fuel pump relay. All fine. I also hooked a jumper box up to the battery to make sure it wasn't a old battery low voltage issue. voltage was reading about 13.3.
I'm now going to contact autocomputerexchange where I bought a reubuilt pcm in 2010 and see what they think. Most likely probably buy a new one and return it if it doesn't fix the problem.
Another side note I didn't think could possibly be related until now is that my parking brake/abs lights have been coming on intermittently as well. I have researched that this is usually a bad rear ABS speed sensor. Could this sensor be related to my other issues? I just ordered one and will install that next week.
Old Sep 10, 2015 | 04:38 PM
  #23
Charvet7's Avatar
Charvet7
Wanted to follow up on this post with the solution. I installed a new Rebuilt ECM for the 2nd time now and the truck is running great. Hopefully this one will last longer than 40k
I guess I can justify installing the new fuel pump by calling it Preventative maintenance.
Thanks for help.
