Dodge prob
Old Sep 27, 2015 | 10:08 AM
98DAKAZ's Avatar
98DAKAZ
Brandybyrd28 what do you mean was cleaned you cant clean a cat.
Now tearing the insides out of the cat yes
Old Sep 27, 2015 | 11:38 AM
WrenchMasters's Avatar
WrenchMasters
Like 98dakaz said you can not clean cats.
Only replace or smash them out so you say it's
backfiring through the tail pipe or intake?
Old Sep 27, 2015 | 12:00 PM
Dodgevity's Avatar
Dodgevity
There are "cat clean" products on the market. Also youtube videos with Scotty Kilmer running a gallon of lacquer thinner in a tank of gas, or taking the cat off and dunking it in soap water for hours. Again, it's rarely ever effective.
Old Sep 27, 2015 | 12:07 PM
98DAKAZ's Avatar
98DAKAZ
rarely ever effective ............. thats correct
Old Sep 27, 2015 | 02:07 PM
Brandybyrd28's Avatar
Brandybyrd28
Thanks everyone, my cousin said he punched a hole in the cat and stuck a rod thru it and punched the inside out, I am no mechanic and I'm beginning to think he's not either, yes it's backfiring thru the tail pipe and the speed hand is bouncing, I have replaced both speed sensors and the computer was replaces about a year and a half ago, please help. I'm a single mother and cant afford to have this truck put in the shop. Any suggestions would be greatly appreciated
Old Sep 27, 2015 | 03:20 PM
98DAKAZ's Avatar
98DAKAZ
A 3.9 Im thinking plenum leak/problem very common and fairly easy fix.
http://www.bobistheoilguy.com/forums...num_fix_w/_pic
You may try this also http://www.dakota-durango.com/forum/...d.php?t=105835
Old Sep 27, 2015 | 11:05 PM
Brandybyrd28
My dad replaced the computer a year and half ago , could it be bad again
Old Sep 28, 2015 | 07:41 AM
Dodgevity's Avatar
Dodgevity
If the cat was gutted, you should be getting a CEL (check engine light). Was it back firing before he gutted it? What state do you live in? Do they have emissions?
What about the plugs and air filter? Also, you might have a bad injector, fuel pump, etc.
Old Sep 28, 2015 | 01:43 PM
Brandybyrd28
He said he stuck a rod thru a hole he made in the cat and no there's still no check engine light coming on, this truck is my only transportation to work, he said he has checked the spark plugs and wires and nothing wrong with them.
Old Sep 28, 2015 | 01:45 PM
Brandybyrd28
Yes it was backfiring before he put a hole in the cat and I live in Ky we dont have to have a cat her
