axle nut size
Quick question. Truck is a 2000 QC 4x4. I am going to change the front wheel bearing hub assy this weekend, and was wondering what size the axle nut is so I don't have to go chasing around for tools in the middle of the job.
32mm socket - needed to remove axle nut
21mm socket - needed to remove 3x hub flange bolts from steering knuckle (Shallow well works
best)
19mm socket - needed to remove lug nuts from wheel
Breaker Bar - to extract high torque parts
7mm Hex socket adapter - needed to remove the caliper slide pins
best)
