My Dakota shakes (?)
Plugs? Coil packs? What engine? Nothing you replaced deals with the ignition system. The shaking is probably from one or more cylinders not firing. I'd be checking the ignition system for a misfire code.
Start off by never going to Pep Boys again. Firestone can be hit or miss. Find a local shop with someone worth a damn or go to the dealer, even if just for a correct diagnosis.
I'm not sure who told you "your tires could fall off" or what a tire sensor is or how it keeps your tires on, but don't go back to that person, especially if it was Pep Boys.
You need someone who knows how a car/truck actually works to read your code and look for a misfire and diagnose it.
