torsion bar adjustment
Old Nov 6, 2005 | 05:18 PM
drjgarage's Avatar
drjgarage
Default torsion bar adjustment
How do you adjust torsion bars? I have a 2003 dakota. Will it hurt my alignment?
Old Nov 6, 2005 | 05:33 PM
DanDB64's Avatar
DanDB64
Default RE: torsion bar adjustment
Right here, I'm sure you will be able to tell where that is, see the bolt right there next to the torsion bar? Just turn it, and it will adjust. The affects on your alignment and ride quality are virtually minimal unless you adjest them too high or too low
Old Nov 7, 2005 | 12:57 AM
thump186's Avatar
thump186
Also make sure you do it on a flat level surface and take measurements from side to side to make sure the ride height is the same on both sides. Here is a link to another post of a basic howto.
https://dodgeforum.com/m_300221/mpag.../tm.htm#300221
