Small MAP Sensor help needed
Old Apr 13, 2016 | 09:48 AM
Frag's Avatar
Frag
Default Small MAP Sensor help needed
Hi guys,
I know I am not the first one having issues with those T25 bolt that hold the map sensor. (Dakota 2000 4.7l engine)
They are rusted out and I need to replace them, and the dealer is useless to my surprise on this... (cant find the part number)
Anyone one of you guys could tell me what are the specs on those bolts? I cant imagine that it could be that complicated to get two bolts loll
Please help here, I have a stuck truck with a bad map sensor. I did not removed the bolt yet, the heads are stripped.
Old Apr 13, 2016 | 11:42 AM
98DAKAZ's Avatar
98DAKAZ
You will need to just get them out anyway you can
I think they are 10mm bolts/screws but remove the old ones to be sure
You should be able to get a replacement from any auto store or home depot you may need to cut them down but the cheapest way to do it.
You may need to grind/cut the heads off the old ones to remove them
