steering rack question
Old Aug 25, 2016 | 07:12 PM
zeus661's Avatar
zeus661
Default steering rack question
Is the steering rack mounted with rubber mounts? I ask this because I noticed when cranking the steering wheel back and forth the rack appears to be moving some in the mounting bolts. Should there be movement where it is bolted to the frame?
Old Aug 25, 2016 | 10:57 PM
magnethead's Avatar
magnethead
Yes, mounted on rubber bushings similar to the control arms. But they slide in and out tons easier.
Old Aug 27, 2016 | 10:17 PM
zeus661's Avatar
zeus661
How difficult are they to change? Do I have to disconnect anything other than the mounting bolts?
Old Aug 28, 2016 | 01:04 PM
magnethead's Avatar
magnethead
No. depending on condition, you can do it one bolt at a time. I did mine when i changed the rack, and they just slid right in, old ones fell apart when i took the bolts out.
