4.7l cranks but no start.
Hey, I'm new to this site but I need some help. I just picked up a 00 Dakota 4.7l 4x4 sport quad cab. It has about 185k on it. It just cranks but won't fire. Good fuel pressure, I used a metal punch inserted into coil boot then held point of punch close to a ground. No spark. Checked for 5 volts at camshaft ps. Good there. I removed the camshaft ps and used a small dental mirror to see if the pass side cam was rotating. It is turning so I know the chain is intact. Took a shoot in the dark and crossed my fingers when I replaced the cam sensor with a new one. Still nothing. Help would be appreciated my next route is to hit the local pull a part yard and get a crank and cam sensor
The cluster doesn't display NO BUS . today I went to the pull a part junk yard and picked up a crank and cam positioning sensor. Swapped them both out and still no spark. It just cranks. A few times it seemed to fire intermittently but not enough to start. Im going to start my diag. OVER tomorrow after work. See if I missed something any more suggestions
would be great thanks
