2003 Durango Brakes = Upgrade?
Old Dec 15, 2016 | 08:36 PM
Dodgevity's Avatar
Dodgevity
Default 2003 Durango Brakes = Upgrade?
Just want to clear this up as I've read conflicting information. I have disc brakes back and front on this 03'. I'm hearing that the 2003 Durango has bigger rotors and bigger calipers... mine is already a twin piston caliper, but I don't mind upgrading if they are bigger.
So are the Durango brakes beefier than Dakotas of the same year? Is there a difference between the 4x4 Durango brakes vs RWD?
See video...
Old Dec 16, 2016 | 08:54 AM
patchelect's Avatar
patchelect
No answer, but have you checked out the replacement part numbers? If they are different they are obviously not the same, although I can't say if they are interchangeable, although they probably are.
Old Dec 16, 2016 | 08:11 PM
Dodgevity's Avatar
Dodgevity
Yeah, I'll be checking into that. I also wanted to see if anyone had done this upgrade and had any insights.
Old Dec 16, 2016 | 09:48 PM
98DAKAZ's Avatar
98DAKAZ
Exclamation
I would think the master cylinder that goes with the Durango brakes would also be needed along with any ABS stuff.
Old Dec 17, 2016 | 09:46 AM
Dodgevity's Avatar
Dodgevity
I think I'm good with current MC. Abs is rear wheels. I'd be doing fronts.
