Daughter`s truck won`t get past 1st gear
Old Jan 6, 2017 | 02:36 PM
gasman_66's Avatar
gasman_66
Default Daughter`s truck won`t get past 1st gear
It`s a `98 Dakota, 3.9, 42RE AT. She drove it to school yesterday morning & it did fine. When she got home, she said it wouldn`t go but 20mph & was tach`n 2 grand. It Is cold here at present time & I know from my `Rango(same year), mine doesn`t like to go into 4th `til she`s warmed up a bit. So, I put some cardboard in front of the rad., warmed it up then took it down the road..it would Not leave 1st gear. Got down to where I was going to turn around, put it R & it didn`t do Anything for 3-4 seconds. It Did finally back-up so drove on back home, left it in N, checked the fluid & it was about 3/4 in. higher then full(so much for it being low on fluid like I`d hoped!). Any ideas/info to help this is Very Much Appreciated!! GAS
Old Jan 6, 2017 | 02:42 PM
gasman_66's Avatar
gasman_66
I`ll add that theres a "growling" noise, infact I checked the power steering fluid because of the sound. Thanks in advance!
Old Jan 6, 2017 | 03:50 PM
tonypilot7's Avatar
tonypilot7
Try letting it idle in neutral for 30 seconds or so before shifting into gear. I may be wrong, but I think on these transmissions, the fluid pump isn't engaged and circulating fluid while in park.
Also, try manually shifting from 1 to 2 and see what it does.
Old Jan 6, 2017 | 04:40 PM
magnethead's Avatar
magnethead
the 4xRE have engaged pump in P/N. Not sure about the newer electronics trans (RFE and such)
It sounds like what mine was doing when I parked it. It's just about terminal. I lost 4th, then 3rd, then 2nd. Now if i try to go more than about 100 feet in first (drive or manual 1), is makes an awful grinding noise.
Old Jan 6, 2017 | 07:01 PM
bomrat's Avatar
bomrat
sounds like a retaining clip that hold the packs in place... thats what happend to my parents 46re.. lost gears, then grinding..
Old Jan 7, 2017 | 02:39 PM
gasman_66's Avatar
gasman_66
Thank you folks for the comments! I`ll admit I`m a shadetree mechanic & right now its in the teens here And my tree has snow under it..lol. magnethead, REbuild or phone calls to junkyards?
Old Jan 7, 2017 | 03:40 PM
magnethead's Avatar
magnethead
If bomrat is right, it should be rebuildable. Mine is in the truck a full year after i parked it, but it's now a project/race truck so it doesn't really count anymore. I did have mine rebuilt the first 2 times though. first time buy a shady place, second time by a legit one.
Old Jan 7, 2017 | 04:14 PM
tonypilot7's Avatar
tonypilot7
The pump may be engaged in park, but it's not moving enough fluid. All of the valve body shift kits I have looked at have a fix for it by drilling out the separator plate.
It's also mentioned in the 42re rebuild thread here: http://mallcrawlin.com/forum/showthr...4-42RE-rebuild Post #4
Mine makes a helluva groaning noise when cold and in reverse only.
I start it up and shift into neutral. after 30 seconds or so, it doesn't do it anymore.
It also has a delayed 1-2 shift but only when really cold.
Old Jan 30, 2017 | 01:07 PM
gasman_66's Avatar
gasman_66
Daughter came home from church last night, said someone asked why she wasn`t driving her truck, she explained about the tranny. Something was said of a `94 being available. I told her lastnite that I Really didn`t figure w/it being 1st gen. So, I just looked on Napa`s site..hmmm, they showed a 42re! Should we More pursue this `94? Thank you All for the looks & advice!
Old Jan 30, 2017 | 05:40 PM
magnethead's Avatar
magnethead
94 would not be a 42RE I dont believe, it would still be a 904 back in those days as I best recall (or a 42RH ). Still, it would not have the electronic sensors you would need.
