Backfiring and shutting off in a 1998 dodge dakota 3.9 V6
Old Feb 4, 2017 | 04:52 AM
marc @ 1032's Avatar
marc @ 1032
Default Backfiring and shutting off in a 1998 dodge dakota 3.9 V6
Sometime ago my mechanic replaced sparkplugs and ever since truck will run well for a while then backfire and shutoff . Since that time the following have been replaced coil twice sparkplugs engine wire harness from engine to computor had to use one from a salvage as a new one is no longer available crankshaft sensor twice distributor. Truck has 120,500 miles.The mechanic mentioned tone ring in the engine block what is it?
Old Feb 4, 2017 | 10:44 AM
HammerZ71's Avatar
HammerZ71
Spark plugs? Spark plugs??? I don't think you meant to post this in the diesel section. LOL...
Moving to proper section...
Old Feb 4, 2017 | 07:52 PM
burcs's Avatar
burcs
Go to an auto parts store and have them test your battery before you keep replacing a bunch of other parts.
Old Feb 5, 2017 | 10:47 AM
HammerZ71's Avatar
HammerZ71
To answer your question, the tone (or pulse) ring is attached to the flywheel and has a series of notches that are read by the crank sensor as they pass by.
How is he determining it's the pulse ring? If it started happening after a plug swap and/or cap & wire replacement it's very likely the mechanic simply misaligned the distributer. Are you getting a camshaft or crankshaft sensor CEL???
