Brake line fittings
Old Feb 6, 2017 | 03:38 PM
booher6288's Avatar
booher6288
Default Brake line fittings
I was told by the person doing the PA inspection of my 98 Dakota that the brass fittings (unions and Ts) on the brake lines I did aren't legal and have to be replaced with steel fittings. The lines I used are steel but I can't find the steel fittings I would need to use to replace the brass ones. Has anyone heard of the brass being illegal?
Old Feb 6, 2017 | 05:15 PM
Depends on the inspection laws. Every place has different standards.
Old Feb 6, 2017 | 05:38 PM
magnethead's Avatar
magnethead
have somebody else inspect it. specifically, a non-english speaking place if you can.
Most unions/T's are brass, not many are steel. I think they just have their head up their ***.
You can also get some masking tape and flat gray paint and see if that will fool the people.
Old Feb 6, 2017 | 07:33 PM
magnethead's Avatar
magnethead
I looked up the law. Brass fittings are fine for flared or inverted flared connections. Compression type fittings are not permitted for any road vehicle.
Old Feb 7, 2017 | 08:37 AM
booher6288's Avatar
booher6288
I looked for a couple days and couldn't find it. Where was it? I'd love to be able to show it to the guy who's failing my inspection.
Old Feb 7, 2017 | 05:35 PM
magnethead's Avatar
magnethead
I couldn't find a direct cite, only several references.
You might ask the inspector to provide documentation.
Old Feb 7, 2017 | 05:37 PM
magnethead's Avatar
magnethead
best reference i have found: http://www.ecfr.gov/cgi-bin/retrieve...se49.5.393_145
