1999 Dodge Dakota V6 2wd Oil pan help?
i have followed these instructions
OIL PAN REMOVAL
(1) Disconnect the negative cable from the battery.
(2) Remove engine oil dipstick.
(3) Raise vehicle.
(4) Drain engine oil.
(5) Remove exhaust pipe.
(6) Remove left engine to transmission strut.
7) Loosen the right side engine support bracket cushion through-bolt nut and raise the engine slightly. Remove oil pan by sliding backward and out.
(8) Remove the one-piece gasket."
and i'm unable to get the oil pan out past the transmission and front cross-member i need about another 1/8 of clearance to remove the pan. any help appreciated
OIL PAN REMOVAL
(3) Raise vehicle.
