Bulkhead connecter pin out
Old Apr 19, 2017 | 08:14 PM
shadowthedakota's Avatar
shadowthedakota
Default Bulkhead connecter pin out
Howdy, I'm wondering if anyone can point me in the direction of the bulkhead connector pinout for a 2000 dakota 4.7l 45rfe 4x4. I found one on alldata but it just had wire colors and pin location. Or if anyone has what wire is for what?
thank you in advance.
Old Apr 19, 2017 | 11:17 PM
magnethead's Avatar
magnethead
When you say bulkhead, which connector are you referencing? Junction blocks C1 and C2 under the dash, Connector C200, or Connector C352 in the left front fender well? I'm very much confused.
The FSM doesn't list function on the large connectors, only the small ones.
Here's C352:
CAV CIRCUIT
1 L1 18VT/BK
2 L62 16BR/RD
3 L63 16DG/RD
4 Y203 16RD/WT
5 L207 18YL/BK
6 B40 14LB
7 L50 14WT/TN
8 L7 20BK/YL
9 B113 20RD/VT
10 B114 20WT/VT
11 K4 18BK/LB
12 K226 18DB/WT
13 A61 16DG/BK
14 Z1 16BK
C200:
C200 - BLACK (HEADLAMP AND DASH SIDE) CAV CIRCUIT
1 V40 20WT/OR 2-
3-
4 G32 18BK/LB 5-
6-
7 G31 18VT/LG 8-
9-
10 A111 10RD/LB
11 Y124 16DG/VT
12 F91 12GY/RD
13 C15 10BK/WT
14 -
15 A19 16RD/YL
16 Y125 16DG/WT
17 -
18 L39 12LB
19 -
20 D21 18PK
21 -
22 D20 18LG
23 -
24 -
25 V23 16BR/PK
26 D22 20PK/BK (4.7L)
27 Y113 18YL/OR
28 -
29 K4 18BK/LB (EXCEPT 2.5L)
30 -
31 -
32 -
33 V30 20DB/RD (SPEED CONTROL)
34 L63 16DG/RD
35 -
36 -
37 L62 16BR/RD
38 T6 18OR/WT (EXCEPT 2.5L)
39 -
40 -
41 -
42 V49 18RD/BK
43 D25 18VT/YL
44 -
45 -
46 D25 18VT/YL
47 Y112 18YL/BR
48 Y119 18YL/TN
49 -
50 T41 18BK/WT
51 Y115 18YL/WT
52 Y114 18YL/VT
53 V45 18VT
54 Y128 20DG/GY
55 Y117 18YL/DB
56 Z2 18BK/LG
57 D25 18VT/YL
58 Y193 20WT/LG
59 A34 16LB/RD
60 V48 18RD/GY
61 L9 14BK/WT
62 A2 12BR/WT
63 C40 12BR/WT
64 A1 12RD
65 A18 12RD/BK
66 -
67 C80 18DB/WT
68 F18 20LG/BK
69 G29 18BK/TN
70 C43 18OR/LB
71 V32 18YL/RD (EXCEPT 2.5L)
72 F32 14PK/DB
73 V37 18RD/LG (EXCEPT 2.5L)
74 V20 18BK/WT
Old Apr 20, 2017 | 12:10 AM
shadowthedakota
c200 the one between the cab and the chassis. yeah what you just gave me is what alldata had too. i started going through individual diagrams looking for the c200 connector and where that wire went into the cab.
i stated bulkhead connector because on the first gen dakotas its labeled as the bulkhead connector.
its for a body swap project im doing thats why i need it and i was on my way to this side of the forum for the fsm when i saw you replied lol
thank you though.
Old Apr 20, 2017 | 06:03 PM
magnethead's Avatar
magnethead
yup, thats from the FSM and it doesn't list the functions per wire. You have to pull that off the diagrams. Which can be done but it's sure hard.
Old Jun 27, 2022 | 12:59 PM
bass1332's Avatar
bass1332
Default Low beam bulkhead five
I am wondering if anyone can tell me the low beam bulkhead connector #5 location on 2003 4.7 L dodge dakota. Thanks
