problems after transmission swap
hey guys i have a 19997 dodge dakota 5.2l v8 and i recently did my first transmission swap. After i swapped the trasmission i have run into a problem. When i shift the truck from park to reverse or drive the car jerks hard and stalls out. I purchased a used transmission from a scrapyard and torque converter that is suppose to be good and has a warranty on it. I also replaced the crank shaft postioning sensor. The transmission has enough oil in so i cant figure out why it wont shift into gear without dying
