Code p0441/ fuel
Old Jul 17, 2017 | 02:17 PM
hidden1's Avatar
hidden1
Default Code p0441/ fuel
I have been getting this code off and on a lot an also checked all lines an tested purge valve an found no problems.
At times though as I release the fuel cap a rush of air comes out .
I've replaced gas cap2 times also.
It's this air noise normal?
Sometimes a faint gas smell is noticed back near tank also.
Any ideas what to check?
Old Jul 17, 2017 | 04:10 PM
Skreelink's Avatar
Skreelink
Having a gas smell near the tank sounds like possibly the vapor/charcoal canister leaking. Look along the drivers side undercarriage, and check for cracks/leaky vacuum lines. I don't have personal experience on a dakota, but I've dealt with one on a Nissan Sentra, it was under the trunk on the nissan, almost in the bumper.
Old Jul 18, 2017 | 12:50 AM
hidden1's Avatar
hidden1
As in the black box itself?
Lines been replaced..maybe loose charcoal in it ..ill recheck it..
How do I test the purge valve?
Is that not opening maybe?
Old Jul 20, 2017 | 09:12 AM
hidden1's Avatar
hidden1
This is gonna soind crazy but true..
I took off has cap when fuel level low an `~~~swish~ a large heap of air released from tank!
​​I filled the tank 3/4 tightened cap an clicked 3 times to close...Reset computer.
I have now gone over 300 miles now with NO CODES.!an added more gas one time with 3 clicks./close! STILL no codes, not even pending!
What gives?!
Does low fuel signal a code or is this 3rd gas cap disfuctioning ..
Seems once that strong air come out an I kept plenty of fuel in it it doesn't set code.
