No start issues
Old Sep 4, 2017 | 12:35 PM
furiousgeorge's Avatar
furiousgeorge
Default No start issues
Hello! I just picked up a '97 reg cab short box with a 3.9 mt. I got it cheap because the kid I got it from couldn't get it running. He said that he was driving it and hit a rough rail crossing, then it quit and never started again. I noticed that the downstream o2 sensor wiring is just hanging there, the connector broken and exposing the leads, the evap canister is gone (and looks like it has been for some time), the lines just flopping around open to the world. I can hear the fuel pump running, but there is no spark. There is no 5v to both the cam and crank sensor. The odometer is flashing, and none of the gauges work. I pulled codes from the dash, and got 920, 921, 950 and 999. THE gauges
all work when it does the gauge test. When I hook my scanner to it, it can't connect.
920- cluster not receiving a vehical message from PCM
921- cluster not recieving distance pulse message from PCM
950- cluster not recieving ABS lamp message from CAB
999- error detected
Those dont look encouraging. Could the o2 wiring have shorted out and damaged the computer?
Old Sep 4, 2017 | 04:17 PM
magnethead's Avatar
magnethead
yep, I'm guessing it's a bad PCM. Being a 97, the EVAP stuff missing isn't a big deal.
Old Sep 5, 2017 | 03:29 PM
furiousgeorge
I figured as much. Rock auto has them for a decent price, I'll give them a try.
