Changing out 2004 dakota oil pressure sender 4.7L
Old Jan 31, 2018 | 08:01 PM
GLWhite's Avatar
GLWhite
Default Changing out 2004 dakota oil pressure sender 4.7L
I've got a 2004 Dakota, 4.7L engine. Do I have to drain the oil before I change our the oil pressure sender?
I've heard it both ways.
1. Oil will pour out if I don't.
2. It's in a separate well and won't leak out.
Any help?
Thanks.
Old Jan 31, 2018 | 08:43 PM
Dodgevity's Avatar
Dodgevity
Any help?
Thanks.
No need to change the oil. The sender sits just above your oil filter. The oil is at a lower level, sitting in the oil pan. You might lose a small amount, so set a pan there anyway. Some say you'll need a special tool, but I changed mine with a small channel lock.
