Odd noise
Old May 1, 2018 | 06:33 PM
hidden1's Avatar
hidden1
Default Odd noise
On my 01 dakota at times going slow or 20-30mph i hear a fast fastfast tap like noise from front ,not often ,an sounds kind of like plastic bags in the wind .
I did just replace brake pads though..
Any thing to look at ..?
Also when going in reverse turning after i stop i feel a front pop.
Is that likely outter tie rod ,or a ball joint?
Old May 1, 2018 | 09:11 PM
Could be.
Old May 2, 2018 | 12:17 PM
hidden1's Avatar
hidden1
Any ideas?
Old May 2, 2018 | 12:39 PM
Inspect the suspension components. Could be anything.
Old May 10, 2018 | 08:27 PM
hidden1's Avatar
hidden1
I did find a outter tie rod bad ,an did the wiggle test on tires..
Seemed tight now.
I back up in turn motion and-at stopping point -POP..
Still ..
Has new sway bar links too.
Is it possible its the brake pads ,they are new an pretty tight ?
What should i look at next ?
