UCA mounting bolt
Old Jun 5, 2018 | 06:01 AM
Alcohol_induced's Avatar
Alcohol_induced
Default UCA mounting bolt
I gotta 99 Dakota rwd that I am putting a new upper control arm on because of bad bushings. It’s got these T headed hex bolts that are discontinued that mount the control and adjust camber. I stripped one out and am wondering what my options are. Nobody has this part, a guy will make me 4 of them for $150. I’m going down to the junkyard to see if I can find any but I’m wondering if I can just use the same size hex bolt and a washer instead? I firgure that’s what people are doing since they stopped making them.
Old Jun 5, 2018 | 08:26 AM
Dodgevity's Avatar
Dodgevity
The head has to be that big and oddly shaped for a reason. I'd be heading straight to the junkyard for those. Bring along a little PB blaster or liquid wrench.
Old Jun 8, 2018 | 07:38 PM
Alcohol_induced
So yeah junkyards won’t sell them to you unless you buy the whole arm. Pick apart you can take them off yourself and buy the bolts. I just can’t believe that their isn’t another alternative out there. I mean if these are necessary why isn’t someone making money off them. Anyway I got some out of pick a part. Breaker bar and pblaster. Put some rustoration on them with a new nut and the threads look awesome. FYI if you are looking for the lower control arm bolt closest to the rack and pinion it’s the leaf spring bolt.
