can a 5.2 engine swap go perfect in a 3.9 f
Old Dec 5, 2005 | 11:25 AM
dakotaman98's Avatar
dakotaman98
Default can a 5.2 engine swap go perfect in a 3.9 f
i have a 98 dodge dakota 3.9 v6 5 speed 2x4 and i want to know if it would work. My engine died on me and if any one knows if it is possibile let me know please, cause i'd like to put on in my truck thanks
Old Dec 5, 2005 | 07:12 PM
Muy_Pyro's Avatar
Muy_Pyro
Default RE: can a 5.2 engine swap go perfect in a 3.9 f
Yes it will work ... how easily and expensive it would be ... I dunno -- But It'll work
Old Dec 5, 2005 | 11:42 PM
tenntech's Avatar
tenntech
I'm not sure about engine mounts, but I sure the pcm and wiring won't work. Something else you might check is the exhaust y-pipe.
Old Dec 6, 2005 | 04:36 PM
acrivers's Avatar
acrivers
It is a pretty simple swap (Opinion Only) The engine mounts should be the same. The only problems would be putting in a new pcm and wiring harness for the 318 swap. Also, your fuel pump would be an issue. You may have to put a different one in place of the stock unit. Lastly your transmission.... your 3.9 transmission should bolt up to the 318, but the AX-15, which i believe is the tranny you have, probably will not be able to handle the abuse if you "hot-rodded" it. You may have to swap it out for the nv3500 and that should be a simple in\out swap. I also agree with tenntech on the y pipe.
Good luck man hope this helps
Old Dec 7, 2005 | 01:08 AM
vipes's Avatar
vipes
what happened to the engine? it seems a little early for a '98 to be dead already...javascript:void(AddText(''))
Old Dec 10, 2005 | 11:40 PM
dakotaman98
My tech told me that a wrist pin came out and messed up a cylinder. He said just to get a new engine.
Old Dec 20, 2005 | 12:16 PM
brian2171's Avatar
brian2171
Here's my opinion of your swap idea.....$$$$$$$$$$$$$$
These things always cost more than you think and may or problably will not go smooth (just my opinion)
Here's what I would do, go to wrecker, get cheapest V-6 you can find, slap in truck, sell or trade for Dakota with V-8.
that's my 2 cents
