2001 brake proportioning elimination ?
Old Sep 9, 2018 | 01:12 PM
rigid's Avatar
rigid
Default 2001 brake proportioning elimination ?
Still can not get the front brake port on the aluminum valve to seal . I have flared new lines. I have bought an M 10 x 3/8 adapter and use store bought flared lines. It will not seal. Starting to think that their may be a split in the aluminum block or something weird. This is a 4 x 4 with RAL only . Rather than spend more time and money on an old rusty truck and have to unhook and try to re-bleed all lines can I just eliminate the valve ?
Thank you
Old Sep 9, 2018 | 05:28 PM
magnethead's Avatar
magnethead
Rigid, I'm going to send you a PM.
Old Sep 9, 2018 | 10:50 PM
rigid's Avatar
rigid
Thank you . I also did the same .
