battery gauge
Old Oct 25, 2018 | 04:43 PM
mggiema's Avatar
mggiema
Default battery gauge
battery gauge pegged out at 18, check gauges light came on. What does this mean. Lasted about 10 miles, then went back to normal for 5 miles then pegged out again.
Old Oct 25, 2018 | 06:34 PM
Need to know the year of your truck.
Old Oct 26, 2018 | 01:59 PM
mggiema's Avatar
mggiema
2000,Dodge Dakota with 134000 miles on it
Old Oct 26, 2018 | 02:09 PM
Moved to the correct section.
Old Oct 26, 2018 | 04:08 PM
Skreelink's Avatar
Skreelink
Sounds like the diode in the alternator gave out. It controls the output voltage, had it go out in my sentra and the alternator started pumping 16-18v and caused all sorts if electrical gremlins. I suggest pulling the alternator and having it tested somewhere before going anywhere else. Overvoltage can blow your ECM and battery.
Old Oct 28, 2018 | 06:32 PM
magnethead's Avatar
magnethead
agreed. Get the alt tested, have them run it for awhile too. Could be heat related. The voltage regulator is in the PCM, hopefully it's still good..
