99 dakota 3.9 to 5.2 swap
Old Oct 28, 2018 | 06:32 PM
Stubbs1999's Avatar
Stubbs1999
Default 99 dakota 3.9 to 5.2 swap
I have a 99 dakota slt 2wd I'm planning to swap the 3.9 for a 5.2 with the matching transmission also 2wd out of a 2000 ram can somebody send me some links on what I would need to bolt in the 5.2 and trans also would I have to swap the driveshaft and rearend any info will help
Old Oct 28, 2018 | 06:48 PM
magnethead's Avatar
magnethead
For the 3.9/5.2 swap, just add 2 injector wires, get a 5.2 or 5.9 auto PCM (a 5.9 will work fine, O2's will correct the mixture but will be a hair fat open loop) and a set of 5.2/5.9 motor mounts (or order a set from Richard at HiPoTek). The 42RE driveshaft might be a hair long for the 44RE, i'm not sure. Trans mount should be the same
Old Oct 28, 2018 | 09:07 PM
Stubbs1999's Avatar
Stubbs1999
Couldn't I just use the the factory motor mounts off the 3.9l they look the same the only mount that looks different is the transmission mount
Old Oct 29, 2018 | 10:07 PM
magnethead's Avatar
magnethead
you can try, i'm pretty sure they are different though. I might be wrong.
