42RLE transmission cooling line check valve
Old Dec 21, 2018 | 06:13 PM
XSubaruJeepDude's Avatar
XSubaruJeepDude
Default 42RLE transmission cooling line check valve
Has anyone here removed the transmission check valve OR replaced it with a larger, higher flow, ball check valve on the cooling line of the 42RLE ? (I just changed my Radiator and though it might be a good time to consider this)
If So.
How much difficulty was there in finding your parts locally?
And what source of instruction did you find the most thorough and helpful?
Old Dec 22, 2018 | 12:09 AM
magnethead's Avatar
magnethead
I think most people just cut it out and splice a length of rubber hose in place, double clamped at each end.
