Humm... wonder if i should put a grease fitting in the weep hole....
I was actually worried about the weep hole filling up with water during wet conditions. Unlike the murray, which had a rubber plug, it was wide open. It also sits in a recess where water blown in by the fan would pool up, I think. I didn't want to clog it though, so I stuck a plastic screw anchor in it and called it a day.
Originally Posted by jondakotaguy
Its starting to get really hard to justify factory OEM when its becoming the same cheap crap as aftermarket.
No lie. You should see the mopar wipers that I recently got. Cheap as anything from Walmart. Looking at the Mopar WP makes me glad I bought the GMB. Aside from having a metal impeller, GMB specializes in making bearings, which is usually the first thing that fails. It was cheap too... roughly 41 bucks.
