interesting transmission issue
Old May 4, 2019 | 11:34 PM
taka21's Avatar
taka21
Default interesting transmission issue
hey everyone, i have an 01 dakota 2wd v6, the issue is that when i manually put the truck in first gear the truck goes backwards like its in reverse. has anyone experienced this or maybe could explain it
thanks
Old May 5, 2019 | 01:28 AM
magnethead's Avatar
magnethead
The FSM does not have a diagnostic description matching what you report.
So all other gear ranges operate normally?
My primary suspicion would be the rear clutch....
Old May 5, 2019 | 08:39 AM
taka21's Avatar
taka21
ok so the other symptom is that it seems like theres no first gear when its in drive either, but once im up to speed it shifts and drives pretty normally, does that go along with the idea that the rear band is too tight?
Old May 5, 2019 | 11:20 AM
magnethead's Avatar
magnethead
NO LOW GEAR (MOVES IN 2ND OR 3RD GEAR ONLY)
1. Governor Circuit Electrical Fault.
2. Valve Body Malfunction.
3. Front Servo Piston Cocked in Bore.
4. Front Band Linkage Malfunction
Not so sure I understand why the FSM suggests a front band issue in that context, it's only used in second gear. Does manual 2nd work properly?
